Winter work Updated NEW YOKES Nearly Done
THE FLUTE
Post by THE FLUTE »
Well the winter work has started Looks good so far!!! :D
Post by Charles »
Looks good =D> Are those 636 forks?
cheers,
THE FLUTE
Post by THE FLUTE »
Yes mate they are Good spot.
Ps got the vavles Fantastic Thanks very much.
Love that bike,pics in viewtopic.php?t=5075.are mint :D
THE FLUTE
Post by THE FLUTE »
pablo wrote:Love that bike,pics in viewtopic.php?t=5075.are mint :D
Cheers for that dude
Its getting there now!!
what yolkes are you using ?
and what year are the forks ? since it looks like you are not using spacers for the calipers, I presume they are 2005 or younger ?
THE FLUTE
Post by THE FLUTE »
JanBros wrote:what yolkes are you using ?
Yokes are Rgv but I'm in the process of trying to make some nice billet ones. Forkes are 2005 636 but even the new ones still use 300mm discs the same as the rgv wheel i'm using
THE FLUTE wrote: Forkes are 2005 636 but even the new ones still use 300mm discs the same as the rgv wheel i'm using
my 2 forkes are 03-04, and they only have 280mm discs :wink:
THE FLUTE
Post by THE FLUTE »
Must just be the early ones that have small discs then :wink:
Kawasaki ZX6R Ninja 2005 UK Specifications
Wheel travel:
front
120 mm
rear
130 mm
Tyre: front
120/65ZR17M/C (56W)
rear
180/55ZR17M/C (73W)
Caster (rake)
25°
Trail
106 mm
Steering angle (left / right)
27° / 27°
SUSPENSION
Front: Type
41 mm inverted cartridge fork with rebound and compression damping, spring preload adjustability and top-out springs
Rear: Type
Bottom-Link Uni-Trak with gas-charged shock, spring preload adjustability and top-out spring
Compression damping Stepless
Rebound damping Stepless
BRAKES
Front:
Type Dual semi-floating 300 mm discs
Caliper Dual radial-mount, opposed 4-piston, 4-pad
Rear:
Type Single 220 mm disc
Caliper Single-bore pin-slide
DIMENSIONS
Fuel capacity
17 litres
mgtkr1
Post by mgtkr1 »
lovely bike, easy the nicest unfaired kr i have seen, in fact the nicest naked 250 full stop less race bikes with bodywork removed. the forks look sublime. is that an rgv wheel you using upfront, how easy to fit?? i whats involved. kep up the superb quality, its a stunning bit of work.
THE FLUTE
Post by THE FLUTE »
mgtkr1 wrote:lovely bike, easy the nicest unfaired kr i have seen, in fact the nicest naked 250 full stop less race bikes with bodywork removed. the forks look sublime. is that an rgv wheel you using upfront, how easy to fit?? i whats involved. kep up the superb quality, its a stunning bit of work.
Cheers Mate Yes it is the rgv wheel Wnated to keep it not to difficult to fit Made a new spindle with lage ends on and had to put 2mm spacers behind the discs.
Thikning of trying to fit this?? What do you think???
http://cgi.ebay.co.uk/HARLEY-DAVIDSON-S ... 2a01922531
don't [-X
Post by 666damned »
jesus...... :shock: :shock: .....you'll need a seatbelt m8y to stop been slung 'over the top'.............
THE FLUTE
Post by THE FLUTE »
Stayed late a few nights at work this week!! :D Making some yokes
si.likes.guiness
Post by si.likes.guiness »
very nice work sir :D
ive seen more tarts than mr kipling
