i want to built some zxr 400 forks in my kr1s.
what is the best way to do because the zxr forks are much thicker.
regards jarno
zxr 400 forks
buzinc
If you are going down the zxr400 route, you need the complete front end from a H model or L model.
The H yoke has same size diameter stem to kr1/s but 2/3 mm longer
The L model has a larger diameter stem. You need to have a stem swopped from a kr1/s onto the L yoke by an engineering company. See Mr Luders pics above
The difference in forks is the L i believe are slightly larger diameter where they pass through into the yoke. The L has longer 'fingers' where the fender mounts
The L wheel is slightly wider than the H!
or do you want 5 spoke kr1s. kr1s will Need modding!
The H model is easier to install, ie no engineering required. (washer/spacer top of triple clamp) But these are getting old and the L is more common.
Dont forget to mod the lock stops!
As Jan says do a search
Buz
Buz
