rear shock oil capacity??for KR-1S
s.mx51
Post by s.mx51 »
hi boys,i gonna service my rear shock,so i need the oil capacity of the rear shock and where i can find shock seals if anyone knows,any info will by much appreciate.thanks spyros
non off the info or parts is available from Kawasaki, so you'll probably have to contact a suspension specialist.
dave32
Post by dave32 »
KYB seals and seal heads are available from "Off Road only in wales",they fit some of the KX models.
There's 2 seal head that are listed as same size but the design is different,get yours apart then match it up with the pic in there catalogue,one is alloy the other is a heat treated colour(black/grey),you want the black one if memory serves me correct.
Oil capacity ive never measured but its not much,under half a litre of Pro RSF 7.5 or 10 will do it.
HTH
s.mx51
Post by s.mx51 »
hi i find the parts i need for the shock,from yz its oem kyb, the oil i use is maxima shock oil 7.5,just waiting the parts to start.
