Radiator upgrade ?
andy b
Radiator upgrade ?
Post by andy b »
I need to upgrade my radiator to bring the engine temperature down as im currently running at 75 degrees and therefore i will be loosing valuable BHP.Does anyone know what radiator will fit my Kr1s as i have tried the RGV curved rad which is currently fitted. I have measured the Nsr 250 m16 and it is like a tiny bit bigger so this wont do. :(
Post by scooble »
I think Spannerman used a TDM rad, I used a Kawasaki KFX450 quad rad. Seems to keep things nice and cool
I have a TDM rad for my KXR500 project. it'll fit but it's a bit wider, haven't checked if this will interfer with the fairing.
spannerman
Post by spannerman »
i was origionally after i think maybe a husaberg or husky rad but stumbled across a tdm 850 rad its getting on for 40mm thick if i remember correctly about 200mm high and 390mm wide, ran it at brands indy on a trackday and the temp kept to about 55/ 60 degrees. just as important everything is correct to just connect straight up.
ade.
on the pipe!!!
andy b
Post by andy b »
Thanks guys, i think im gonna see if i can get a tdm 850 rad then , Hello Ebay!!! :D
spannerman
i recall i paid £ 40.00 for it and it is very good condition. from a local bike breaker
on the pipe!!!
andy b
Post by andy b »
Do you know the dimensions of the rad mate?
spannerman
as above to within about 10mm andy.
on the pipe!!!
spannerman wrote:as above to within about 10mm andy.
just measured mine, they are spot on =D>
andy b
Post by andy b »
Thanks guys, guess i need glasses #-o or a reading lesson :)
NOS EXUP
Post by NOS EXUP »
Try using a PACE radiator- made specifically as upgrade for KR1S
NOS EXUP wrote:Try using a PACE radiator- made specifically as upgrade for KR1S
Where can you get these from?
Post by alimorg »
You could try Sean at The Tuning Works sure he used to have some
AL
spannerman
arn't they about £400 or am i thinking of something else, i get like that now i'm clocking on.
ade.
on the pipe!!!
NOS EXUP
Post by NOS EXUP »
Yes about 400 and worth every penny
Have you tried Sean to see if he has any left ?
