Fork bleed screw
twostrokesmoker
Fork bleed screw
Post by twostrokesmoker »
Anyone know the bleed screw size (pitch) ?
Phil.
salty
Post by salty »
I can check on Friday - might have a spare if you want it.
Salty
Professor
screwed
Post by Professor »
there isn't an air bleed screw on the KR1s forks, do you mean the oil drain screw?
If so M4x0.7 pitch std metric coarse, phillips pan head m4 x 8 with a small oring which seals it
Hardcore you know the score
twostrokesmoker
Fork bleed screw
Cheers Prof, sorted
