oh and its a very mice site u guys have here!!!
wot up ppl im new to ur site!!!
member
hi all im all the way from south africa. uhm if got a little problem or dnt no if thits little or big, but yesterday i was driving on my way home frm work and the bike just cut out for no reason? any help???? oh and its my 2nd kr-1S 1st 1 only had a stator problem so i sold it just cause i got my hands on this one im the second owner since new!!!!!! i bought in from an old guy. will post pics asap!!!!! its the muzzy style paint job! plz any help???????
1992 kr-1S
Welcome to the forums.
Your problem could be anything, so you'll have to go through some basic troubleshooting techniques and eliminate possible issues one by one.
First thing to check would be fuel and electrics.
What were the circumstances and symptoms when it stopped and how did it stop?
A few more details there might give us some clues as to the area you need to start looking.
Also, what's your electrical and mechanical background like?
member
well about the kr-1S my machanical nd electrical is not that good i never had any probs b4 with it this is my first so ya i never had to do fault finding b4 lol
what i can tell u is that i was driving in it sudenly just made like if u would to switch the bike on nd off and just when i thought it was noting it just cut out. i already bypassd the on nd off switch its not that. so ya wot cn u tell me??? if u need more info just ask!! thanx
1992 kr-1S
KwakOn
Hi,
checking if you still have a spark at the plugs is fairly simple;
there are other things like is the plug oily, caked up, correct gap etc.
you maybe know this anyway.
- remove spark plug and
put cap on it
turn ignition on (fuel off, choke off)
kick it whilst holding plug cap so that body of plug is in good contact with engine block (earthed)
if there is a spark you should be able to see it.
repeat other side.
(take both plugs out makes it easier to turn engine over).
KwakOn
Jnaus
member
i know that if i would 2 be the side stand the bike would start in neutral but would die when u put it in gear. uhm to tell u the truth the bike shops near me didnt even know that the bike exists.... so ya hahah. uhm how can i check if its my stator? if u guys can post sum pix on how 2 go 2 work it would be nice.... but other wise just plain good explaining would do the job! thanx
1992 kr-1S
I would suggest you take a look at page 15 of this PDF...
http://www.kr-1s.co.uk/manual/Part%2015 ... System.pdf
Reading that will probably all make sense, but if you have any questions please ask.
