Just a cpl of pics of my ugly duckling growing up
Im now at the nice stage where everything is clean (even me).
cheers
iain.
http://i646.photobucket.com/albums/uu19 ... C01963.jpg
http://i646.photobucket.com/albums/uu19 ... C02012.jpg
http://i646.photobucket.com/albums/uu19 ... C02037.jpg
http://i646.photobucket.com/albums/uu19 ... C02049.jpg
http://i646.photobucket.com/albums/uu19 ... C02053.jpg
Becoming a swan.
iain250
iain250
Thanks lads you caught my garage at a tidy moment - 3 weeks ago it was a different story as my wife has an unhealthy obsession with the number 4 - this number 4 to be exact
http://i646.photobucket.com/albums/uu19 ... tagain.jpg
- kwackman12
Bloody hell that takes me back! I remember a girl from my subaqua club bringing one of those to my garage with a broken timing chain, made a few enquiries & there was two ways of doing it, the first was to remove the engine & gearbox, remove the timing chain then refit, the second (a lot cheaper) was to remove a plastic cover on the inside of the car on the bulkhead, remove (cut) a 12inch square in the cars bulkhead (you could then change the timing chain without removing the engine) then weld the plate back in place! She took the cheap option, mind you she did return home to Australia about six months later
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
ZXR 400 Race Bike
Aprilia RS250
- smithyrc30
Wouldn't you have been better just pushing it of the top of a mountain... You have a few to chose from up there...iain250 wrote:crazy machines - her last one i had to put nearly 2m2 of steel into - i kid you not - bright yellow i might add
32bhp as well (well in 1982 ) prob about 25 now - what a weapon
4...... ummm..... YUCK!!!
the closest Ive gone to that dark side is a...
http://commons.wikimedia.org/wiki/File: ... pe_001.JPG
just like ...but in blue
glorious Two Stroker - the doors used to pop open when you went around a corner hard enuf !
539cc of screaming triple at 100kph (@6000rpm? revvd to ?9000?)
I had to drive home on a couple of occassions in peak traffic with no clutch! (broken cable) luckily it was so feather weight you could start the motor in gear and bang through the box
CLASSIC, GOOD TIMES
CLASSIC, GOOD TIMES
