Hi,
Got me a kr1 which i bought as a non runner for a project. The non running was rectified by a top end overhaul and eventually,new carbs. Anyway,i was forced to leave it a while(even tried getting rid) but recently was hit with a sudden attack of enthusiasm and spare time!
The engine,whilst seeming to run ok(though i couldnt check that on the road due not havin MOT etc) started blowing smoke through the left exhaust. I figured that the crankshaft oil seals were on the way out. Deep joy! So what im wondering is,can you tell just by lookin at the seals whether they goosed or not? I'd hate to blow stacks of dosh sending the crankshaft away for no reason...
Also,whilst strippin the bike down(its completely in bits now with frame and swingarm at the sandblasters) i noticed that there was oil in the airbox. Ive never seen that before,could the two be related somehow?
Thanks in advance....
Crankshaft seals...
spoggster
Oil in the airbox could be blow back from the carbs so as long as its two stroke oil its fine.
I've not seen gearbox oil get that far back in the system before ( the reeds should stop it for one) its generally sucked into the cylinders past the leaking seal and burnt or the oil is blown though the gearbox and out the overflow during the piston down stroke (generally its a mixture of the two).
If your unsure of the condition of the crank, then IMHO its best to get new seals fitted (about £50 last time I checked) by someone like BDK, who can also inspect the various parts, bearings etc. and can advise on what is needed to restore the crank back to original condition. Depending on how bad the crank is expect to pay anything from £50 to £300. They will ring you with a quote before proceding though. Its worth it for peace of mind, For an extra £100 you can fit a new top end while your at it as well.
Yes, sympotms can vary though, mainly its a loss of gearbox oil (being burnt or blown out of the air vent), and/or running lean (LHS outer seal seals to atmoshpere and not the gearbox). Also a loss of power, and generally poor running can also result.spoggster wrote:Is a dodgy seal not usualy associated with running rough?
Generally rough running, can be caused by either fuelling problems or electrical gremlins.
Sheik Yerbouti
spoggster
