Hey guys treated myself to a pretty pair of Mitaka pistons and when I opened the pack of piston rings there are a top and a bottom ring and a very thin corrugated “ring” bit like what they used to fit in four strokes in the oil control ring.QUESTION IS:— WHAT RING DOES IT GO UNDER— no instructions or diagram in box.
Col
Piston ring location Mitaka
NOSHER
KRI
CBR250RR
CBR400RR NC23
vfr400 nc30
KRI
CBR250RR
CBR400RR NC23
vfr400 nc30
Re: Piston ring location Mitaka
behind the bottom ring I suppose.
NOSHER
That’s where I thought it should be Jan.
Col
Col
KRI
CBR250RR
CBR400RR NC23
vfr400 nc30
KRI
CBR250RR
CBR400RR NC23
vfr400 nc30
NOSHER
Yes it would appear now that there is a lot of controversy on the web as to this “expander ring”which does as Jan surmised fit under the bottom piston ring and has been known on many occasions to break up and cause havoc and expensive damage inside the motor and the consensus of opinion appears to be “Don’t fit them”.
Col
Col
KRI
CBR250RR
CBR400RR NC23
vfr400 nc30
KRI
CBR250RR
CBR400RR NC23
vfr400 nc30
