KR1 Refurb.
KR1 Refurb.
Not really a project - but have been transferring everything from my KR1 / KR1S hybrid on to a new frame (old one had damage) since just before the winter.
Sprayed the new one and polished the main frame spars.
Everything has been checked/cleaned/sprayed/lubed as required as i went along. Replaced most of the manky fasteners and put good
a lot of neglected jobs over the years.
Almost finished now and looking forwards to starting it up and refitting the body work.
First time out the shed today :P
Re: KR1 Refurb.
often wondered, is how much stiffer the KR-1S frame is to a KR-1
second moment of area says about 9.4% stiffer
the 0.7mm thicker main spars will add estimated 400g to the KR-1S frame weight
Rolex
Re: KR1 Refurb.
Post by Rolex »
Looking good any more photos?
Re: KR1 Refurb.
on my old B I filled the frame rib depressions with black vinyl strip (kitchen draw vinyl)
also around swingarm pivot
saw someone do it once on the original old e-box ZX-10
quick and simple mod makes the KR-1 frame look more different and 3 polished ribs will really pop.
since you are going with black accent vs polish
Re: KR1 Refurb.
No photos Danny?
Re: KR1 Refurb.
...parked on a shelf next to the Ark :P
I got the vinyl at local hardware - resisted going for a wood veneer inlay look that was other choices on offer
Gerrit
Re: KR1 Refurb.
Post by Gerrit »
Pity I couldn't find a 1S frame for my project- a 9% increase in stiffness is a worthwhile gain which more than compensates for the slight weight disadvantage.
Frame stiffness
factory frame mods to other bikes: road to race trim (such as YZF750) included welding plates on key areas to stiffen.
the 9% stiffness KR-1S advantage could be eliminated between the two by doing either of following to a KR-1 frame...
1. glue a 80 x 1.2mm sheet along the inner face of each beam
OR
2. glue/weld a 20 x 2.5mm strip along the top edge of each beam section
I suggest glue/bonding because unknown what weakening affect welding could do to the frame over large area.
BUT I wouldn't bother - less weight is better. Nothing wrong with a KR-1
Re: KR1 Refurb.
Danny,
I think some nice mahogany veneer in the KR1 frame troughs would solve the stiffness issue and be aesthetically very pleasing :lol:
Re: KR1 Refurb.
Passed on the veneer suggestion
Had it running - just a leak one carb due to an oval fuel pipe clip, replaced it and seems okay now
A few fairing repairs to do then should be ready for MOT
podman
Re: KR1 Refurb.
Post by podman »
Looking good mate...
Re: KR1 Refurb.
Thanks
All back together now
Just need a shakedown run up the lane then get it MOT'd - with a pass hopefully :oops:
Re: KR1 Refurb.
looks smart with black wheels and blue number boards
podman
Re: KR1 Refurb.
Post by podman »
Agreed, particularly like the black wheels...damn sight easier to clean as well!
c&c
Re: KR1 Refurb.
Post by c&c »
Very very nice...
