Do KR1S wheels fit in a KR1 ?
I know the swingarm is different and the fork lowers and calipers but can it be done ?
Do KR1S wheels fit In KR1 ?
- Garry
Re: Do KR1S wheels fit In KR1 ?
If you have the correct fork bottoms and calipers it can be done (yokes are interchangeable between models)
You will also need the spindle, speedo drive (different spindle diameter) and spacer (again due to different spindle size), also different discs
Rear goes straight in - but you will need the correct spindle for whichever arm you are using (S spindle is longer)
Think that's it
Think that's it
no need to change the yolk. Yes, they are different, but not in size.
