Engine set up
skinnybob
Engine set up
Post by skinnybob »
Ok I've tried everything and still the left side is running hotter than the right, can anybody recommend someone to set the running up for me in the north of England. Would be very grateful!!!
mellorp
Re: Engine set up
Post by mellorp »
big place the north, where about are you ?
skinnybob
Re: Engine set up
Post by skinnybob »
North Manchester but I put north of England as I'll travel to anyone that's good and recommended. Thanks.
the Re: Engine set up
Hi Skinnybob,
Have you started from scratch and cleaned and synchronised your carbs?
If you get no other offers, I am in Teesside just outside Stockton on Tees.
mellorp
Re: Engine set up
Post by mellorp »
I'm in South Manc near the airport You are welcome to call round
skinnybob
Re: Engine set up
Post by skinnybob »
Thanks very much, any idea on the base setting for the air screw (number 6 on the diagram in the KR1S manual) i.e. how many turns out from fully in. I can't find this in the manual, just a setting for the pilot screw! Thanks very much for your offers.
mellorp
Re: Engine set up
Post by mellorp »
page 21 of 89 in the supplement says 1 1/8 turns out. You can set this by listening to the engine note.
clean all components, fit/oil air filter. check carb to airbox and carb rubbers for cracks. Make them pliable with olive oil and warm water
set needles on correct clip (4 on the kr1 manual)
set float heights
set free play in the cable
set slide heights
adjust tick over right side to 3k with left plug out then do the left side
reduce tickover screws by same amount to get even 1100 to 1300 tickover with both plugs in
set the air screw fully in then wind out 1 1/8 turns (1 1/4 turns KR1 manual)
the bike should start without touching the throttle
test initial pickup and if its too rich wind the screw out (more air) or too rich in (less air)
tighten all the cable adjusters
check oil pump
Re: Engine set up
original air screw setting is too lean, better start with 3/4th out
skinnybob
Re: Engine set up
Post by skinnybob »
Sorry to be pedantic folks but the manual only details the pilot screw (at 1 and 1/8 turns out) and not the airscrew. Is the airscrew the same?? Very grateful for your responses.
Re: Engine set up
Same
