I was working over the weekend on getting my fuel cell mounted to the bike.
I want everything quick release and as easy to remove as possible.
To achieve this we added a tab either side to the rear of the tank to rest on the rear sub-frame.
We also made a front mount, which will be fixed with an "R clip" through a spigot.
The rear of the tank is held in position under the sub-frame cross spar.
I will fix the fibreglass tank around all this from the tabs that are on the top of the cell.
I have kept the filler neck over to the right side, so it's easy to fill when the feul filling jug is full.
The total cost of this was in the region of £300 which includes the cell, filler neck, TZ fuel cap, TZ fuel tap and materials for all the fibreglass.
What I get from this is a lighter, quick release tank, which is designed around the bike and shaped to match all the lines.
Total weight saving about 550g
