sorry... where is the engine and chassis number located
rhyde
Post by rhyde »
sorry guys, having a hard time finding the location of the engine number for my 91 kr1s
could anyone show me pictures please Of where it is
kind regards
rob
rhyde
Re: sorry... where is the engine and chassis number located
Post by rhyde »
5 views no responses
anyone please
SP_BOTT
Post by SP_BOTT »
Just above the clutch operating arm, on a nicely cast lug, have a look at pics 5-6 in the link
http://www.ebay.co.uk/itm/KAWASAKI-KR1- ... Swr41XH2wA
sorry forgot, the frame number is stamped on the RH side of the headstock, same as 'every' other bike.
rhyde
Post by rhyde »
thank u so much for that
appreciate it
but I'm still struggling to see where it is on my engine
is it covered by something i.e. carbs
could u please tell me what side it is on if I'm sitting on the bike, i understand where the clutch side is though
but f**^()k why can't i see this
or better yet pics to point to where it is
I'm really sorry i know i must sound like an idiot
rhyde
Post by rhyde »
see pics if someone could point out where for me that would be mega awesome
I'm loosing my mind here lol
Post by jarno »
top picture behind the clutcharm there must be the number .
if it is not there it is possible the have changed the cases with new ones at one point,and than there is no number stamped in the cases.
rhyde
Post by rhyde »
behind here?
if the case has been replaced how can i get find the engine number
if i can't find the engine number i can't register it.
SP_BOTT
Post by SP_BOTT »
Yes that's right, probably under the frame, but follow it back towards the middle of the engine, and it should be stamped on a shamfered casting, on the front edge of the top crankcase. You should be able to see it without ripping anything off.
SP_BOTT
Post by SP_BOTT »
There is a possibility it's been filed off, for some reason, as I think it's a solid casting??
rhyde
Post by rhyde »
its definitely not there
i have no idea what to do now as i don't know how i can register it
this is a big problemo i think
Post by jarno »
The only thing you can do to check is to lower the engine by taking the upper enginebolt out of the frame.
if there is none marked in the cases, just have one stamped in them.
Post by alimorg »
JanBros wrote:if there is none marked in the cases, just have one stamped in them.
I borrowed a stamp set from a blacksmith to do a chassis number on a kit car - just make up any number and register it with that!
rhyde
Post by rhyde »
Well thanks to the very kind Ian B
i was able to find the numbers. What a task, i thought i was loosing my mind
thank u Ian b
