ZXR yokes to KR1s
Wheels, shocks, forks, frame
britaxcooper
ZXR yokes to KR1s
Post by britaxcooper »
I've found a set of yokes (I don't have a KR1s anymore) that I think are ZXR400. How do I tell if they've been fitted with a KR1s stem? Can someone give me dimensions please?
The top yoke has a top hat in it to reduce the ID.
Re: ZXR yokes to KR1s
If it has the top hat spacer they have been adapted for the KR which has a narrower stem than the H model ZXR. (the bottom yoke should have a bush in it as well).
H has the same bearrings as a KR, so it will be form an L model because those had a bigger stem
britaxcooper
Thanks guys, so it'll fit back in the zxr or can be used (with spacer) in the KR1 =D>
