WATER LEAK
old bloke
WATER LEAK
Post by old bloke »
Got the project up and running today but it has a water leak, there is a little hole in the casing next to the drain bolt on waterpump housing which is where it's coming from what this? and why's it leaking please?
old bloke
Post by old bloke »
sorted found it in the manual posted on here, it's the mechanical seal on the waterpump thats gone tit's up
slashing
Post by slashing »
You can stilll get the mecanical seal fom kawasaki wemoto do it also just a case of taking the iner and outer clutch cover off you cant get the water pump gaskit any more but a good bit of gaskit paper will do the job.Hope thats some help it is a common problem.
