Anyway sat in the garage about 830 or whatever tonight and started pulling it to bits then thought its like a 2 stroke really. This is a late 1969 unit single 250 BSA B25 Starfire but even then we were still turning out pre unit engine designs but stuck in one casing. It not surprising the British bike industry went under. The cases split vertically so prone to leaks and the geabox has its own oil and is linked to the engine which is dry sump and its own entity via the clutch which just sits on the end and a primary chain.
Looks like any other modern engine from here apart from the gear change is on the right side and thats the oil tank not a panel just draining hence the pipes dangling about
Check out the other side once the casing is off though and the drive is exactly the same design as the 1949 BSA B31 pre unit i have. This side you have to put 1/2 a pint of oil in for the chain to run in so three seperate lots of oil.
Probably not the place for it but i just thought it might interst some of you.
I will just get me coat then i havent quite finished reading the phone book yet
