Managed to make up a wee puller that worked a treat
I turned a bit aluminium down to 28mm (same as spindle), about 25 - 30mm long. Drilled a 7mm hole in the centre, then elongated it to measure 10mm oval top to bottom. Finally cut it in half top to bottom.
You can then slide the halves into the centre of the swing arm, and insert a 10mm threaded rod. This opens the 28mm out to 31mm, which is enough to get a catch on the bearing edge, and draw it out via the threaded rod and a spacer.
Worked great
Tommy
