So I could have the head rewelded, or opt for trying to make head-inserts for an original head. The second option hasn't been tried, so the descision was quickly made
going through the chamber :
thickness off the head at 56mm diameter ( with 2mm removed from the head-surface compared to an original) :
and ready for inserts :
took some measurements while milling away material, to have an idea of the available material for normal head-machining :
numbers are recalculated to an original head (check the height of the surface on the head-bolts) these aren't exact figures, as I couldn't take the head of the mill for accurate measurements, but might be of help to anyone machining heads ? (might explain the dip at 51 and 47, as it looks rather strange compaired with the other numbers)
next making the inserts, shouldn't be too dificult on a lath. I had to to the head-work on a mill, 'cause the head can't go round on my lath. Due to having to switch tools/centre points not an easy job on a mill to get both ecxactly the same
biggest problem will be sealing the coolant arround the KIPS-holes. There is just enough room to have an O-ring seal go round the entire cylinder, but there is no room arround the KIPS for an extra ring next to the O-ring to seal the combustion chamber
