crank seal failure?
dirk
crank seal failure?
hi folks,
my crank is ~ 4500 miles old.
now RHS exhaust smoke much more than LHS.
it smokes with cold engine much more then LHS and smoke very much especially i accelerate fast the first time after the engine is warm or after a longer time with lower revs.
rev up the (warm) engine in idle it smokes too. not much but you can see it.
i feel no power loss but the engine splutter a bit at ~4500-5500.
RHS spark plug is a bit darker then the LHS.
i can’t say 100 percent whether i loose gear box oil or not because i have a leak in the clutch cover and loose some millilitre at every tour but the symptoms are the same as my old crank.
the only different is my old crank leak only with warm engine and the exhaust was not smoke more when the engine was cold.
i don`t understand this....4500 miles is not a long time for a crank seal and the bike is only a road bike.
what is the cause of crank seal failure?
cheers
cheers
- the-elf
Is the RHS smoking more than usual or the LHS less?
It does sound like it might be a crank seal on its way out.
dirk
hithe-elf wrote:Is the RHS smoking more than usual or the LHS less?
thats a very good question =D>
yes the LHS smokes only a few after start the engine (cold) and if i play with the throttle the RHS smokes normal.
the LHS end can is uncommon dry. perhaps only one oil drip .
normaly both endcans are wet if the bike run on road.
Only after few miles on "Autobahn" both end cans are dry
spark plug is between dark gray and light brown.
RHS all in all darker but it don't look to rich.
ok what have i done the last weeks
the LHS carb was flooding and i have changed the needlevalve and checked the float hight on both carbs.
and yes after this work i have for the first time noticed that the RHS exhaust smoke more than LHS.
so far so good but what can happen with the carbs?
i am very sure that the float hight on both carbs ok (19mm)
one gallon gear oil??:shock:garye345 wrote:When my crank seals went(twice),it bloo the oil out every ride,did 30 mile to the gallon-oil
- the-elf
K if the LHS is smoking less it sounds like its running lean. Check for air leaks or a crankcase air leak first. Try swapping the carbs over from Left to right hand side and see if the problem follows.
The LHS outer crank seal is to air (Stator) and not to the gearbox so that could also be sucking in air, it is also the easist seal to change.
dirk
- the-elf
Dirk, We have all had a few problems, but look at it as a challenge. The trouble is with any 20 year bike is that things will always fail, but its worth it when they go well. I had a simular problem last year and it turned out to be a crankcase air leak on the LHS.dirk wrote:hi
thanks for you help.
i hope that is only a problem with the carbs or the manifolds.
sometimes i think it is better to sell this bike.
you can believe me i am a bullet proof 2stroke fan but the KR is till today only a maintenance nightmare![]()
dirk
What a bad day.
first i found some gear oil under the crankcase.
left side under the shift mechanism cover........
and then i saw a very long crack (more or less from side to side) in the RHS
bottom engine mount.
last year there was no crack.
Words fail me.
Words fail me.
- the-elf
On the outside of the motor? If so that might be just a leaking seal/gasket and not a major problem.dirk wrote:What a bad day.
Thats a very normal crack in any frame of the early 90's. It's due to sloppy tolerences from the factory. Measure the width of the engine and frame mount and get a shim made to remove the slop between them.and then i saw a very long crack (more or less from side to side) in the RHS
bottom engine mount.![]()
Words fail me.
Two choices, if the weld is only partally cracked then drill the tip (down to the un-fused land), or get it dressed out with a drimmel and rewelded. If its not too far gone and the mount is still attached to the frame
mgtkr1
mine has no cracks but its a bloody wonder!! bottom mount must of ha .25 mm of slop!!!!!! even when torqued up the spacer was able to spin round easily. dirk, has your bike had diffrent cases at some stage in recent yrs! seems odd that a crack has developed in the last year when its been ok for 18-19yrs? maybe the alloy fatigues ect with age. i found that an old shim from the gearbox works perfectly for shimming the bottom mount. hth. i feel for you dirk, not nice when you have problem after problem with your pride n joy. look at it like this, only so many things to go wrong on a kr. before long it will be 100% reliable with mostly new parts!! id change suppliers/crank builder ect just to try and improve your run of luck. your supplier may have a batch of friday night special spares (bad batch/poor qc)?? who knows.
dirk
hi
the crack is to long and the gap to thick for a repair with a shim.
i hope i found an aluminium welder.
that is not easy and i think very expensive.
and then i hope i found what´s wrong wit the engine.
with my luck a crack in the crankcase and the crank seal.....perhaps barrels and pistons, gearbox
it's all ok
but the engine mount... nightmare.
during my first full rebuild i had changed the crank and the crankcase.
perhaps the "new" crankcase was a bit to small.
thanks for the tip with the shim.
it's all ok
KwakOn
Mine had the same crack, as Elf said, you can run with it.
A friend is an experienced welder and he assured me there was still plenty of strength left as the mountings are welded in enough places.
the shim doesn't repair it - just takes the stress off it.
I ran mine for a couple years like that (not clever but safe enough), repaired it month or so ago and found that the bolt (engine) hole also had cracked.
Fix engine first, probably air leak or something, welding should be cheap - half an hours work.
..- the-elf
The only thing about welding Alloy is that the set needs to be DC, while for any other material its welded using AC (or is it the other way round). Anyway if your getting it welded, do the prep work yourselve by Veeing out the crack first as that'll save the welder time. The welding it-self shouldn't cost much at all.
