Help...
I have no spark at the plugs... which I've traced back to the ignition/kill switch circuits.
There is power to the ignition switch, but not to the kill switch. No fuses are blown, and the CDI has power where it should. Are there any hidden fuseable links or fuses apart from the 3 in the fuse box? I didn't see any in the wiring diagram.
It's a 91 KR1-S
No spark at plugs
gytr_r1
- Newbie
gytr_r1
- Newbie
- the-elf
Yes, but the most common reason for a knacked CDI is a failed regulator, so once its running check the regulator as per the manual as well.
gytr_r1
- Newbie
Yeah I read that on another post in here after a bit more trolling... Thanks for the replies by the way... We'll replace the regulator anyway as the original one looks fairly corroded on the heat sink, and it all failed after a ride in the rain...the-elf wrote:Yes, but the most common reason for a knacked CDI is a failed regulator, so once its running check the regulator as per the manual as well.
