Following on from...
- SHimmer45
not sure if some thing like above would have enuff muscle to run what is required on a KR, id say u would have to work out how many amps is being drawn run the bike is running.
it could be possible as the battery doesnt need to turn the bike over to start it.
might be worth looking at what racers use, as you might be able to get a very small gel battery which could be hidden in the rear seat pod maybe
Can get a standard battery in under the seat hump, will do that
You can see the offsett of the nc swingarm mountings here
Oh well it was a scrap frame anyway, seemed a shame to take a hacksaw to it, but this is the bottom linkage mount liberated from it, need to cut the kr one of and get it welded in.
The last time Liverpool Fc won the league, George Michael was black and Michael Jackson was straight or visa versa, it's that long ago I get confused.
if you start the bike with your lights switched off, you need 0,0V from the batterySHimmer45 wrote:not sure if some thing like above would have enuff muscle to run what is required on a KR, id say u would have to work out how many amps is being drawn run the bike is running.
and once the engine is running, only at idle the battery has to jump in to keep the lights burning at full strength
I never considered It would have any offset
. I thought it would be a case of sorting linkages , Not what your getting into.
Your going to give yourself a reet chewing there chief
. Your as crazy as a shithouse rat
Lets know if you need spacers or materials i might can help. Alan.
- Light Smoker
blown away!!!
f..cking hell red devil your masterpeices are the bollox im so bleeding jealous,well done mate cant wait to see whats coming next,im stunned =D> =D> =D>
fast fred 1s hooligan
Yep me neither, Alan, all the stuff I've read about them never mentioned it, NC24 isn't offsett, so that'd possibly been the way to go, but still would have ben fun, because it's much wider (220mm?) and not a solid tube on the pivot point (dunno if the spindle runs through the engine cases) So you could shorten it to get it in but would there be enough left for it to be strong enough.alanw wrote:I never considered It would have any offset. I thought it would be a case of sorting linkages , Not what your getting into.
Your going to give yourself a reet chewing there chief. Your as crazy as a shithouse rat
I could get the Aprillia AF1 swingarm in, a piece of piss, but thought that a bit of a retrograde step, as it's steel, wasn't quite certain about it's
strength in comparison to standard/other arms and the wheel is a bit narrow (same as a kr1 takes a 130/140), it is a 17 incher tho! It fit's in just needs a couble of thin spacers) You can get it to go into a kr1 frame by removing the 'top hat' bushes and using the kr1 internal bush which fits straight in. Because it's one of the 'uses 2 side bits' swingarms on the pivot point it would go in with the kr std shock/linkage. Then just weld on a mounting for the dog bones to go to, in the same relative position as the kr arm, jobs a good un
And before anyone says Aprillia 125 chain on the other side! All you have to do is turn it upside down.
Anyone want to see a pic of it posed in there for future reference? Might use it in another chassis, would probably look ok in a valve, my main concern is, would it be strong enough?, If so it could probably go in a kr with a standard 110/140 front/rear tyre set up and look ok, but this one's got a zxr400 3.5 in front with a 120 tyre............
I know open out the zxr250 yokes to take 636 forks (no probs cos it's got 400h forks in now) off the green bike, swap front ends........................
oh bollox to it anyone want to buy a load of scrap metal
- 666damned
"oh bollox to it anyone want to buy a load of scrap metal"..............pmsl...............
..............you need committing to a house run by men in white coats Mark.............
- ScottaKR
My hat's off to you Mark..... That's some serious commitment to building a custom KR!
=D> =D>
That'll have to be the most heavily customised KR in history, and I'm sure will be a stunning bike.
KR250 Tandem Twin (Naked)
The point of no return has passed
Well, if the single sider was going in, I had to make some frame mods at some stage (yeah should have done before the powder coat.......)
Removed the bottom linkage mount and trial fitted the nc30 one that I cut of the h***a frame, I've just drilled and tapped it at the moment, it'll all get welded up later.
Also worked out the top shock mount, I've tried to mock it up in this pic, I've ordered a solid ally bar to weld in across the frame using the holes in the frame that are there to allow access to the original shock mount (if you follow me
From there, I'm going to mount the rgv shock mount on a soild block of ally with a hole drilled through it for the solid bar, then all welded up.
Hopefully you can work out what I mean from these couple of pics
Oh yeah that shock isn't going in, it's just for mocking it all up
- the-elf
Red here is what I did for a battery.
Works excellent. Its a set of AA cells for a remote controll car made into a 12V battery
Not a huge amount to update, bit of a bugger when you're waiting for bits, still waiting on top shock mount hopefully here for this weekend. One day I'm going to buy myself a lathe and learn how to use it which could be fun as I normally work in tolerances of plus or minus a yard
Anyway, got the swingarm vapour blasted, brought it up like new, think I'll keep it like this, although black is a possibility, polished is not! Dunno what do you lot think?
Back wheel is off to the powdercoaters, that's deffo going black, still not certain if it'll end up in it or not, might look for a 3 spoke job to match front. Had quite a bit of stuff vapour blasted, shock, rear master cylinder etc comes up a treat.
Front end has had a bit of work, done the leg bottoms black to match the gixxer calipers, looks better than having, gold tubes, brown fork bottoms and black calipers. Just mocked this pic up cos I've lent BarryJ the bushes etc so he can see about fitting a zxr wheel into his rgv, well I suppose you have to let them use some quality kwak parts on their Suzukis, Sean's always fond of reminding us that we use the occasional rgv part
Also got a good set of kr1 discs from Gary(e345), so using them instead of the prolite(s) (mucho cheaper
) but centres black rather than gold.
If anyone wants any 636 axle bushes give me a shout as I will probably be getting some more made.
- SHimmer45
