Engine dies when hot
Wolfgangh
lurker
Post by Wolfgangh »
Hi, I finished a complete ground-up restoration of a KR250A. I was very happy when it started almost immediately at my first attempt, and I let it run a few minutes in neutral to check for leaks etc. Then I rode it a few hundret meters around my garage, to check the gearbox, suspension, brakes etc - all fine. As soon as the temp gauge approached the mid the of scale, the engine started to miss some beats, the tach needle was jumping ( i.e. betweeb 0 and actual RPM), I was able to keep the engine alive for some more time with throttle action, but it appeard to me that 1 cylinder was first cutting out and then missing. Since the tach is driven from the front cylinder CDI, I assume it is this cylinder which makes problems when getting hot. Since I have an almost complete spare bike, I started to swap parts - one at a time: spark plug, coil, CDI. So far no change. That leaves the pickup or the exciter coil. Before I prepare everything to remove the left side engine cover to get access to these parts (which requires draining the coolant, removing the oil pump...) I wanted to ask you for any further ideas or inputs. What else could it be? If the exciter coil cuts out, wouldn't this affect both cylinders the same?
Aussietandemtwin
lurker
Re: Engine dies when hot
Post by Aussietandemtwin »
Hi , did you solve your issue, mine has similar symptoms.
