Marmite #2
Re: Marmite #2
Post by headcoats » Thu Oct 18, 2018 7:17 pm
It's just an RGV250 swingarm that has been blasted then sprayed then rubbed down to find the imperfections :oops:
Re: Marmite #2
Post by 500bernie » Fri Oct 19, 2018 8:20 am
Hi Martin,
It looks like you found a few.
A bit of work required there to get that to your usual very high standard.
If you get fed up, send it to me and I will give it a good polishing for you.
Bernie 8)
Re: Marmite #2
Post by headcoats » Fri Oct 19, 2018 7:30 pm
Plan is to get it powdercoated and rub down the banana side face (eh) then a bit of Upol filler then have it satin black sprayed and hopefully it will look good
Re: Marmite #2
Post by headcoats » Sat Jan 19, 2019 11:44 pm
