Cheers Martin, i dont think I need to change them at present. I just saw in the service schedule that the needle bearing needed lubricating periodically , and I thought I havt done them!
Unless i get any wear I will probably leave well alone.
PS Martin engine has done over 600 miles since you rebuilt it , running sweet. Trust you are well
swingarm bearing replacement
- Binetta Steve
- martin
Re: swingarm bearing replacement
all is good steve. thanks for asking.
glad you are happy with the rebuild.
I am building a special engine for a forum member at the moment.
flowed crankcases
v force reeds
lightened flywheel
29.6mm carbs
300cc conversion
correct squish on the head
mick abbey tuned barrels
2 standard and 2 f3 valves
bdk powervalve pulleys
and linkages
flowed crankcases
v force reeds
lightened flywheel
29.6mm carbs
300cc conversion
and linkages
