Oddjobs KR1 B2
Cheers for all the replies I,m still waiting for the shock to be returned, they have said it will be ready next week. Then it will be tyres from a local bike shop ( Bridgestone BT92 £195 a pair ) . I have got the barrel back from B.D.K with new pistons etc so i,ll have to re-build the engine . Then i will start putting things back together which i,m looking foward too
I got the rear shock back this week so i painted the spring and fitted the swinging arm and shock.
Have also cleaned the barrels and cylinder head of the old gasket and everything is ready for assembling
I also have had the new tyres ( Bridgestone BT45s ) fitted so the wheels went back on. I tryed to get BT92s but nobody had them stock. The next job is to put the engine back together and fit it in the frame but the weather looks nice for sunday so we will be going for a blast
The original is still available from any kwak dealer. Check out
http://www.cmsnl.com/kawasaki-1990-c2-k ... E1111.html
for part nos
110041177 about £20 odd + postage
for part nos
, I have put the engine back together and fitted it into the frame. It was not as difficult as i thought it would be, also fitted a kawasaki head gasket. The kips were tricky getting everything the right way round.
Since then i have fitted most of the rear end, carbs ( after a good clean ), oil tank, water tank and the new battery. The wiring loom has also been fitted and i tested the kips motor which worked a treat.
Today the radiator went back on and the new front sprocket and chain were fitted
The next job is to order some brake lines and get them working also to give the exhausts a good clean and paint then re-fit them.
If anyone has any tips for cleaning out the inside of the exhausts i would be grateful.
