source for new KR250 Tandem Twin fork tubes ?
pepsi
Where can I get a set of new good quality fork tubes ?
pepsi
Re: source for new KR250 Tandem Twin fork tubes ?
I wonder if these will work? they have the same part number ,44013-1222
http://www.bazar-de-la-becane.fr/tube%2 ... asaki.html
http://www.webike.net/sd/21921894/
pepsi
dougindoors
there is some on ebay aus prob be cheaper than shipping from the UK
1984 Kawasaki KR250A
2 Smokey and they bandit
pepsi
do you mean these used ones? They have the same deep pits that mine have. Whats up with that?dougindoors wrote:there is some on ebay aus prob be cheaper than shipping from the UK
http://www.ebay.com.au/itm/Front-Suspen ... Swd4tUFlSy
StrokerBoy
As ScottaKR said, it'd be better to get yours rechromed. In the UK Philpots are keeping all our old bikes on the road, is there anywhere near you that offers a similar service ?
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
Yamaha RD350LC,
pepsi
I do not think rechroming will fill in the pits, wouldn't the new ones in the ebay listing, work?StrokerBoy wrote:As ScottaKR said, it'd be better to get yours rechromed. In the UK Philpots are keeping all our old bikes on the road, is there anywhere near you that offers a similar service ?
StrokerBoy
I don't know if they'll fit or not.
You'd be surprised what can be restored. Pits aren't a problem, even slight bending can be rectified.
Yamaha RD350LC,
Yamaha RD350LC,
dougindoors
the rechroming process does not just mean a coat of chrome philpots grind back the tube until its below the pitting then apply chrome back to the original diameter approx. £100 per tube, I need to get a pair of AR125 tubes done, ouch but the only answer.pepsi wrote:I do not think rechroming will fill in the pits, wouldn't the new ones in the ebay listing, work?StrokerBoy wrote:As ScottaKR said, it'd be better to get yours rechromed. In the UK Philpots are keeping all our old bikes on the road, is there anywhere near you that offers a similar service ?
pepsi
I might look into it, thanks for the info.dougindoors wrote: the rechroming process does not just mean a coat of chrome philpots grind back the tube until its below the pitting then apply chrome back to the original diameter approx. £100 per tube, I need to get a pair of AR125 tubes done, ouch but the only answer.
I want to get the bike on the road to see if the forks leak, as it seems the pits are above where the seals ride.
heres a close up of the pits on the fork tubes that are listed in Japan, they are like mine.
dougindoors
if the pitting's above the seal running area there's no problem, I read an article in cmm about repairing pitted areas with araldite and smoothing them back, I have tried it and it worked for a while, you really need to clean the rust right out to get it stick proper.
sulli
Hi Pepsi thought you might find this interesting
http://www.radhardchroming.com.au/Page/ ... nditioning
Gerrit
Surely there are companies in the US that offer a similar service?
