Has anyone fitted RGV 250 forks and then refitted the KR1S wheel ?
Can it be done and what discs,calipers spacers etc do you use
Can the speedo drive be fitted o.k. too ?
Right i have bit the bullet and now this is the mod i will be wanting to do so if anyone has any info please.
Is there any reason it wouldn't fit ? what problems might i come up with ?
Not as far as I know.
I've been lurking on this, and other, forums for too many years and I haven't come across it done. It may have been done in the 90's but I've never seen anything in print about it.
Good Luck!
I have an Aprilia RS 250 wheel for the back and needed a similar 5 spoke front wheel but with a speedo drive because i'm keeping the standard LC clocks .
Saw a KR1S with RGV forks and a KR1S front wheel at the Stafford show but had no camera
But it looked like it used the KR discs and even the KR calipers
