KR1S PISTON RINGS COMPATABILITY WITH B PISTONS
Posted: Sun May 30, 2021 7:43 pm
by NOSHER
HEY GUYS--THE CRANK IS ON ITS WAY TO PJ ENGINEERING FOR A REBUILD BUT MY QUESTION IS CAN I USE RIKEN KR1S PISTON RINGS ON MY ORIGINAL KR1 "B" PISTONS ?
ALSO I KNOW THEY ARE LIKE AS RARE AS CHICKENS TEETH BUT IS THERE ANOTHER SUPPLIER OF KIPS VALVE SEALS WITH THE "WIPER" LIP THAT ANYONE KNOWS OF?
CHEERS
COL
Re: KR1S PISTON RINGS COMPATABILITY WITH B PISTONS
Posted: Mon May 31, 2021 4:26 pm
by SP_BOTT
Not sure about the rings, but when looking for the seals, just find some 'R23' type as these are double lipped, Got mine a good few years ago now. (probably from simply bearings) don't think they are hens teeth...rare
Posted: Mon May 31, 2021 8:51 pm
by NOSHER
THANKS FOR THE REPLY FELLA---HAVEN`T TAKEN OLD SEALS OUT YET DON`T SUPPOSE YOU REMEMBER THE DIMENSIONS OF THE R23 SEALS YOU BOUGHT ?
JUST DISCOVERED MY KIPS VALVES ARE TOAST-----THE OIL SEALS HAVE PUT A GROOVE IN THE SEAL VALVE STEM AREA SO EVEN WITH NEW SEALS THEY WILL LEAK AGAIN.
Posted: Tue Jun 01, 2021 7:17 am
by SP_BOTT
This says they are still available, a little pricey though
https://www.fowlersparts.co.uk/parts/view/92049-1238
assume seal would also be 8/14 too possibly 4mm depth after looking on here
https://simplybearings.co.uk/shop/Seals ... index.html
also seen this a while ago, as I got the dimensions off this thread
viewtopic.php?f=8&t=46434&p=134475&hili ... al#p134475
Posted: Tue Jun 01, 2021 10:16 am
by NOSHER
thanks for the reply the info is really interesting never thought of stabilising and sort of sealing the shafts with double seal roller bearings .
now ill have to prise out the old seals and measure the orifices(holes!!) for compatible bearings.
thanks again--this crank rebuild with all parts req is getting a bit wallet slapping so if i can save the old kips it will knock £200 off the bill hopefully---I think its about time i put my loft full of kr1 parts on ebay to help pay the costs.
Thanks again
col
Posted: Tue Jun 01, 2021 11:09 am
by SP_BOTT
How much is the crank rebuild going to cost?? PJME and BDK seem to be around £400 looking at their websites, (plus webs etc if required)
