Is the ignition mod worth it?
solomonheckler
Post by solomonheckler » Sat Feb 29, 2020 8:28 pm
I'm sure this has been covered many times before so I apologise if I'm repeating but I'm just about done with my C3 renovation with Jollymotos, just wondering if the Zeeltronic is worth the £s. I'm not gonna race it but would be nice to get the thing as good as I can without redoing the ports etc.
I have the dyno use for myself when I need, wanna get the bike right first.
Any tips, advice, maps etc, much appreciated.
Graham
KR1-S 250 (C3) 1991
CBR250RH Hurricane 1987
TZR125 4FL 1995
stevo135+
Re: Is the ignition mod worth it?
Post by stevo135+ » Sun Mar 01, 2020 12:07 am
I don't know about KR1S's specifically, but I've been told that a programmable ignition allows you to tune a given pipe to suit the engine better, and can improve performance before the power band and after peak power rpm? I'm using one on my lowely KMX 125, and my pipe builder told me it'd make a good difference to performance with everything else set up too. It's got to be more worthwhile on a bike like a KR1S's or RGV too!
mellorp
Post by mellorp » Sun Mar 01, 2020 9:26 pm
Zeeltronic is well worth the pennies. Plug and play. Here you go with a decent KR-1S map
00:
01: PCDI-10VT <device ver>
02: 00 <boot ver>
03: 22.140108 <software ver>
04: 0000 <data ver>
05: 44.4 <static angle>
06: 12500 <rev limit>
07: 30 <delay comp>
08: 2 <pulse per rev>
09: 1 <ign setting nr>
0a: 13.5 23 25 26 18 15.5 7 9 9 9 <ign angle #1>
0b: 15 24.5 26 19 9 5.1 5.1 5.1 5.1 5.1 <ign angle #2>
0c: 1200 3000 7500 8000 10000 11000 13000 14000 15000 16000 <ign rev #1>
0d: 1500 3000 7500 10000 12000 12800 13000 14000 15000 16000 <ign rev #2>
0e: 7 5 <nr ign points>
0f: 12000 <shift light>
10: 500 <kill time>
11: 0 <ign sw>
12: 0 <advance>
13: 1 <pv setting nr>
14: 150 <pv close>
15: 915 <pv open>
16: 5 <pv deviation>
17: 1 <pv test>
18: 6 2 2 2 2 <nr pv points>
19: 0 20 40 60 80 100 100 100 <pv angle #1>
1a: 0 100 100 100 100 100 100 100 <pv angle #2>
1b: 0 25 40 100 100 100 100 100 <pv angle #3>
1c: 0 10 40 80 100 100 100 100 <pv angle #4>
1d: 0 100 100 100 100 100 100 100 <pv angle #5>
1e: 6900 7000 7300 7600 7800 8000 10000 10100 <pv rev #1>
1f: 7000 7100 8700 8800 8900 9000 9100 9200 <pv rev #2>
20: 7000 7200 7500 8600 8700 8800 8900 9000 <pv rev #3>
21: 6900 7000 6500 7500 8300 8400 8500 8600 <pv rev #4>
22: 7400 7500 8200 8300 8400 8500 8600 8700 <pv rev #5>
23: 2 <trigger Mode>
Coose
Post by Coose » Mon Mar 02, 2020 6:45 pm
I wish you hadn't said that, Phil.... 8)
