Rear Seat Cowl - ABS Sheet
Plastic bits and Paint
Post by 500bernie » Mon Oct 29, 2018 6:57 pm
Hi Guys,
It has been a while since I have polished anything or undertook any plastics repairs or fabrication, so I thought I would let you have a look at my current project. It is for one of the members here on the forum (my mate John Farley).
I have one of Davey's very nice cast resin set cowls for my 300, but after doing my last lot of extensive plastic repairs to a top fairing, I thought "How difficult could it be to make a seat cowl from scratch"?
Well it turns out that it is not that difficult, but it is bloody time consuming.....
What do you think (3mm ABS sheet)
Not finished yet, as I need to replicate the parts to hold the seat cowl in place and to lock it down using the standard seat unlocking parts.
And then do the final finishing to ensure it flows nicely with the tail unit lines.
Bernie 8)
Re: Rear Seat Cowl - ABS Sheet
Post by Gerrit » Mon Oct 29, 2018 8:06 pm
Looks jolly good so far!
Post by 500bernie » Mon Oct 29, 2018 11:04 pm
Thanks Gerrit 8)
Post by Gerrit » Tue Oct 30, 2018 11:30 am
Are you going to produce a complete range of ABS KR parts, Bernie? Tail units, side panels, fairings even???? :shock:
Post by 500bernie » Tue Oct 30, 2018 9:46 pm
Hi Gerrit,
Perhaps when I retire, I think most parts could be made if you were determined enough to put the time and effort into it.
I have done some extensive repairs to top fairings, bellypans and tail units. Including fabricating large replacement sections from ABS sheet.
I enjoy doing it, when I get a bit of spare time I will upload some photos of what can be done with a bit of time and effort.
Bernie 8)
Post by Binetta Steve » Tue Oct 30, 2018 11:13 pm
Nice work Bernie , bit of a cottage industry developing at Bernie towers. I trust the RAMS are all in place 👍
Post by 500bernie » Wed Oct 31, 2018 11:38 am
Hi Steve,
A very slow cottage industry.
RAMS......LOL
Bernie 8)
James P
Post by James P » Sat Nov 03, 2018 1:35 am
Nice work Bernie. It looks as if the Beet replica vents should present no problems 8) .
Post by 500bernie » Sat Nov 03, 2018 10:14 am
Hi James,
If you have a good photo, so I could gauge the size of the larger vent, I will put it on my to do list.
Cheers Bernie 8)
Post by KR-1R » Sun Nov 04, 2018 8:07 pm
I don't like the way they bubble outward of the fairling. The rear face of the duct could be brought closer to the sparkplug/radiator in a 90° arc
to copy one thing is plagiarism - to copy two things is called research
Post by 500bernie » Sun Nov 04, 2018 8:26 pm
Hi Danny,
Nice photo, I have never seen a close up of one before. Do you think the intention of the larger vent is to redirect the warm air flow from the radiator away from the motor and rider, or to increase the low pressure behind the radiator to increase the through flow for the radiator? Or a bit of both?
Any more photos or dimensions would be greatly appreciated.
I think I need to buy some more ABS sheet.
Bernie 8)
Johnfarley
Post by Johnfarley » Sun Nov 04, 2018 10:13 pm
All looking good Bernie 👍 top job as usual if you’re thinking of making them vents I would be interested for my 300cc 😉
Kr1s-c3, Kr1s-c2,
Post by 500bernie » Sun Nov 04, 2018 11:46 pm
Hi John,
That makes two pairs on the to do list now.
Bernie 8)
Post by KR-1R » Mon Nov 05, 2018 11:05 pm
needs some coach bolts to be authentic :lol:
got any pics of the underside of yours, to see how you glued/formed/welded yours?
idea: router a seat pad mold from MDF (or other). Cut out KR-1 italic logo from your 3mm ABS sheet. Glue it in and paint for release/surface finish. Then cast a PU seat bum stop pad with the KR-1 logo inset into it 8) 8) 8)
