bad starting
rockerted
bad starting
Post by rockerted »
any ideas..hard to start, eventually does fire up,leave a couple of hous go back and fires second kick usually..good spark..petrol seems to get through..goes well once running,but sometimes ticks over at 3000, and eventually drops back to 1k :roll: :roll:
remember, you can strap a monkey to a rocket, but that won,t make it a pilot..
Tambo
Post by Tambo »
Sounds like an air leak. Perished carb rubbers , or vaccum hose ??
Other than that, perhaps a sticky carb slide, but that normally makes the revs rise much more.
Let me know how you get on.
Good luck !!
sprocket stu
poor starting
Post by sprocket stu »
we have changed the vacuum pipe as it wasnt sealing very well and the next step is the inlet rubbers
try petrol tap in prime position and see if that makes
a difference
LEE MAFFS
Post by LEE MAFFS »
Sounds like carb rubbers air leak or throttle cable sticking?> :wink:
rockerted
post
Post by rockerted »
changed vacuum pipe, changed petrol tap, and finally carb rubbers, my mechanic (sprocket) unpaid, balanced carbs etc, 1 kick this morning.. :lol: carb rubbers looked well perished, so think they were the main cause, just to keep u informed tambo..thanks for all advice :lol: :lol: :lol:
Tambo
Post by Tambo »
Nice one !! 8) Satisfying to get a result before there's an expensive bang :roll:
sprocket stu
poor starting
also turned oil pump down as it was over oiling i think it may need a hotter set of plugs now the weather has turned it is only getting used for shortish runs ( like most of them at this time of year)
my old gt380 used like hotter plugs in the winter to prevent them fouling up
