KR1S Rear Sprocket Wanted
Need some bits ask here
Post by headcoats » Sun Jun 10, 2018 6:14 pm
Does anyone have a spare KR1S rear sprocket gathering dust please :P
Or an alloy one used for just a few times on the track etc ?
Many Thanks :mrgreen:
Re: KR1S Rear Sprocket Wanted
Post by headcoats » Mon Jun 11, 2018 10:50 am
Are Kr1 and KR1S rear sprockets the same dimensions ?
Post by Garry » Mon Jun 11, 2018 4:13 pm
Yes same fitment
KR1 is 40t KR1S is 41t - but i guess yours is for your hybrid LC so you will have your own idea in mind
Post by headcoats » Mon Jun 11, 2018 4:37 pm
40T is probably the better option then
Post by headcoats » Thu Jun 14, 2018 2:42 pm
So the KR1 and KR1S both use 520 chain ?
On flebay they are seling JT sprockets
Are they any good ? anyone used them ?
Post by Garry » Fri Jun 15, 2018 6:11 am
They both use 520 chain - and JT are good sprockets
You may be able to save a few pounds if you buy items individually from different sellers
If its for your hybrid not sure how you will determine chain length (unless you are using the same set up as on your first one)
Post by headcoats » Fri Jun 15, 2018 2:15 pm
I have an RK 120 link chain which I bought a few years a go
Got a Talon offset front sprocket at 17 teeth and a 40 tooth rear sprocket is on it's way
Yes it's for the Hybrid !
This build has been on and off so many times now :cry:
With the Athena 392 top end going on , it makes this a different animal
No power valves , so it will behave like the original LC :shock:
Post by headcoats » Sat Jun 23, 2018 3:02 pm
https://www.ebay.co.uk/itm/Kawasaki-KR2 ... 2749.l2649
Bought this and it doesn't fit :shock:
The holes are a smidge too far to the outer edge
Are KR1 and KR1S carriers definitely the same ?
If so then the manufacturer ain't got it right ?
Post by JanBros » Sat Jun 23, 2018 3:08 pm
you don't have to tell us, tell the seller or check the dimensions.
Post by headcoats » Sat Jun 23, 2018 3:19 pm
Yes I know but it will make KR owners aware JT sprockets don't fit
Post by Garry » Sat Jun 23, 2018 7:59 pm
I bought a JT rear last year and fitted ok - never had a problem changing rear sprockets
Are you sure the sprocket carrier is for KR1/KR1S and not KR250A
Hole centres for sprockets on KR250A are 130mm, for KR1/KR1S they are 156mm
Post by headcoats » Sat Jun 23, 2018 10:17 pm
Garry it can't be the other model as 130mm wouldn't even come close to the holes :shock:
My carrier has the 156mm holes but the sprocket holes are a tad off
I have emailed JT sprockets too about this as I think it's a bad batch or something
This pic shows the sprocket on the other side but shows the mismatch
Post by headcoats » Mon Jun 25, 2018 5:08 pm
Well it has turned out to be a fake FFS !
Contacted J T Sprockets direct who were very helpful and confirmed the finish, stepped machining and the stamp on the back are all dodgy
JT sprockets should have a "sun" logo stamped on them with a separate long number , I guess batch identification
They suggested to get one from Wemoto as they are an official stockist
This bloody bike is fighting me every inch LOL
podman
Post by podman » Mon Jun 25, 2018 8:32 pm
Thanks for reporting your findings mate...
Post by Garry » Tue Jun 26, 2018 6:34 am
I should let the seller know (they may not know they are fake) - they should offer a refund
If no luck report it to Ebay
You should be able to get your money back
