here i go again !!
kwackman12 wrote:Your garage seem's a bit tight for work space there Doug i'd happily get that old red bike in the picture out of your way f.o.c of course :mrgreen: :mrgreen:
F.O.C. :shock:
Never seen a bigga bag a bollox in all my life as that piece a shite :^o :lol:
dougon2wheels
Post by dougon2wheels »
bugger........ :(
got her started after fighting with a dodgy coil(as soon as i plugged one of the leads in,it wouldn't start !)
managed to find another coil now she runs on both cylinders..... :P
but.......
did a compression test when cold,95 and 100 psi,warmed it up and.........85 and 90 psi :evil: ,worn rings i thought,stripped the top end but everything is within spec,very slight wear showing on the barrels but nothing to worry about
bloody crankseals :cry: i'm going to have to try and find some money to do the crank now :cry:
dougon2wheels
the crank's been stripped now.....and the center pin is buggered too....another one on its way from bdk,more money....
i've also been playing with my zinc plating tank,i've now done every bolt on the engine ](*,)
Tripitaka
Post by Tripitaka »
What type of plating have you had on the other components,is it zinc/nickel?
Neil.
dougon2wheels
Tripitaka wrote:What type of plating have you had on the other components,is it zinc/nickel?
Neil.
its zinc with a yellow passivate
dougon2wheels
got my wheels done,and got some new disc's(thanks pablo !)
shame its still being a right bitch to start though......anyone got a spare cdi i could borrow ?
I like the front discs and calipers old fruit 8)
What are they and where did you get them :P
dougon2wheels
headcoats wrote:I like the front discs and calipers old fruit 8)
front disc's are ebc's (part no. md4008rs md4008ls)and the calipers are from a blandit 1250 (same as gsxr's k1,but newer and less sought after,got mine for £45,with less than 1200 miles 8) )
Looking good doug.You don't hang about d'ya =D>
kwackman12
Post by kwackman12 »
dougon2wheels wrote:shame its still being a right bitch to start though......anyone got a spare cdi i could borrow ?
Iv'e got one you can borrow Doug, pm me if you still need it
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
dougon2wheels
body work now fitted............had to take a drimmel to the fairing to remove the large amounts of filler,so the mirrors would fit #-o
the rear shock seems a bit worse for wear,so i thinks i may go for an r6 jobbie,mind you,maxton don't charge that mush to rebuild the standard unit.......oh,i wish i wasn't so skint at the mo.....
iain250
Post by iain250 »
Looking good can you tell me what paint or plating youve used on the rear caliper - it looks spot on.
dougon2wheels
its some leftovers after painting some stuff for my kids..............plasti-kote,fast dry enamel......gold leaf,i think it was 99p from wilkinsons.....lol
dougon2wheels
had some time at work to get on with doing the zxr 400 front end.....
i've also fitted the r6 shock,works surprisingly well even in standard form,ride hight is a tad high though,46mm,i thin i'm going to have to rework the dogbones......
dougon2wheels
got the front end fitted into the bike,got the mudguard thanks scooble :D
just got to have a play with the dogbones(for the timebeing till i can afford to have the shock modded) to drop the back a little.......
then to find another decent painter..........
