not rev'ing past7500
Re: not rev'ing past7500
Post by Garry » Thu May 31, 2018 2:12 pm
Do you ride with your lights on
I have always found the lights on these bikes tend to drain the battery down (i don't think the charging circuit is very powerful - personal experience but i may be wrong)
If your battery is not very good you may not be getting enough power to operate the power valve motor and lights at the same time (7500rpm)
May be worth getting a new battery if yours is a few years old
Not sure if this will help
Post by JanBros » Thu May 31, 2018 10:34 pm
I've never had an even remotly decent battery in my bike. There is always one in, just to swallow the excess of current made by the charging system. My battery is so dead the bike won't start with the lights on as they (lights and battery together) drain too much power from the ignition while kicking.
But once that the motor is running, everything is fine, and we must have our headlight always on.
So no, the charging system is plenty powerful and lights on does not drain the battery. There must be something wrong with yours Garry.
Post by Garry » Fri Jun 01, 2018 6:16 am
I know you do not need a battery to start the bike Jan, and you need it for the excess current.
However does it not operate the powervalve motor ?
I can only tell you all my bikes and electrics always work better with a decent battery
Marty_Rillo
Post by Marty_Rillo » Fri Jun 01, 2018 11:23 pm
Hi there!
I have had this kinda thing happen a few times.
Now for the conflicting experience.
On my bike, as the revs increase, to around 7500;rpm, if my battery is shit flat, I get this happening.
But I'm a cruel bastard, and I hold the old girl open, soooo.
Once the powervalves have cycled open she explodes into life again.
Now here's what was happening.
The bike can start just fine with no battery, it can also power a light when running, and as the revs rise you get the regulator doing its job, and battery charge etc.
But as the powervalve motor started to cycle at 7500 it was drawing all available current, and this meant that the coils didn't have the required voltage and I was getting a dull spark and no power, and brick walling.
Very odd.
So that happens pretty much every time I flatten the battery leaving the ignition on.
The end.
Cheers Martin.
Post by JanBros » Sat Jun 02, 2018 9:37 am
it doesn't when switching on the contact. but the electric charging system always makes enough current to ride and use everything on the bike and extra to charge the battery.
maybe if the battery is too dead drawing away too much current, what Marty say's is happening.
Mouser
Post by Mouser » Sat Jun 02, 2018 7:48 pm
Ok, guys, that's worth a try!
I'll just connect a strong starting battery to the bike and warm-up the bike standing and trying if the valves switch at 7500.
@Martin: Maybe in your case the valves switch but there is no mor power for the spark....in my case the valves do NOT switch, they don't even move a f... little bit.
But, thanks for mentioning it, I will try it. My battery is very likely past its best years...
thanks
Mouser
Mouser
Post by Mouser » Sat Jun 09, 2018 6:09 pm
Hi guys,
I tried to connect the bike to a strong battery....the valves still won't move at 7000rpm.....
I checked the rectifier one again. The charging current is max 14.5V at 5000rpm...is this too much, should I change the rectifier or is this still ok?
So as for the valves....I think the problem will finally be the CDI :(((((.
Anybody got a spare CDI for the C3?
please mail me @ carmeni1@hotmail.com
thanks guys
Mouser
Post by Binetta Steve » Sat Jun 09, 2018 7:20 pm
Post by Gerrit » Sun Jun 10, 2018 10:40 am
If the regulator/rectifier is still the original one I'd replace that even if it seems to be working properly. The originals aren't the best and the last thing you want is for another CDI to be fried. The experts on the board can advise you on a suitable one.
21119-1234 is the KR-1 CDI, and 21119-1287 is the KR-1S CDI according to the Cradley Heath website. The KR-1 CDI will probably work on a 1S, but as I understand it the ignition advance curve is different. Not sure whether you'd notice any loss in power, though.
It might be worth investigating whether anyone can repair duff CDIs as they are No Longer Available from Kawasaki.
Mouser
Post by Mouser » Sun Jun 10, 2018 11:55 am
My rectifier is not the original one anymore, I changed it 3 years ago, to avoid having a fried CDI.....it has run maybe 2000km....max...
If the 14.5V at 5000rpm are still normal...than this cannot be the issue...nevertheless the CDI seems to be fried....
Yes, indeed the one on ebay is a KR1 CDI.
Anyone has tried both CDI on a KR1-S ? Any noticable power difference ?
Anyone got a CDI to sell :( ?
Mouser
Post by Gerrit » Sun Jun 10, 2018 5:37 pm
HPI in Belgium (www.hpi.be) offer a repair service for OEM CDIs according to their website. I don't know whether that includes the KR-1 and KR-1S iggy units, but there's no harm in asking. Nothing ventured, nothing gained and all that.
podman
Post by podman » Sun Jun 10, 2018 8:15 pm
Could you not fit a zeeltronic?
http://www.zeeltronic.com/page/pcdi-10v.php
At least it would be a new, working item without the SH gamble...
Mouser
Post by Mouser » Mon Jun 11, 2018 8:36 pm
Thanks for your replies!
How about the voltage. Anyone knows exactly if 14.5V at 5000 rpm is still normal or does that harm the CDI'
thanks
Mouser
Post by JanBros » Mon Jun 11, 2018 10:27 pm
14.5 is perfectly normal. above 15.5 is troublesome.
Marty_Rillo
Post by Marty_Rillo » Mon Jun 11, 2018 11:49 pm
Noo den mouser!
I have some info that may help.
Not guaranteed though!
When I first got my kr1s, then my electrician friend came round to solve some problems on it.
One of the screw ups he found was the stator and pickup wiring was butchered.
Thier are three wires from the pickup, and one or two go to the cdi.
The bike would start but wouldn't know where it was on the cycle, and as I wound on the throttle it would rev to around 7500 to 8000 and just brick wall.
It would also spit out a lot of oil fuel from the silencer!!
Matthew then swapped two wires in the connector block around and pop!
Off we went! perhaps the issue is in the wires telling the cdi what rpm it is like that?
Cheers Martin.
