compression
Posted: Thu Oct 23, 2008 9:17 pm
hi folks
today i have measured the cylinder compression.
the head was reworked, because the head was warped.
Squishband is reset and the sqish clearance is now 0,9mm.
both cylinder and piston are new (0km)
i have measured on both side cold at full throttle.
with open valves ~10.5bar (~152psi) and closed valves ~11bar (~159,5psi).
or was it reverse..
i dont know.. it was a long day...
the manual said that the usable range is between 7.3bar and 11.3bar.
(107-164psi)
but the last value is very high or not?
regards
dirk
or was it reverse..
(107-164psi)
regards
dirk
