Page 3 of 5
Posted: Tue Oct 13, 2009 7:14 pm
by KwakOn
Looking good (as usual)
got one of those wee engines a while ago
cant wait to start fitting it - but I will have to as I need to finish the rebuild that I have started (race bike with lights
It will be a proper job yours, I will try and build mine so it can swap with the standard engine which might not work
Posted: Wed Oct 14, 2009 8:10 pm
by FLaT-SiX
Jan.......it's impressive, fantastic project =D>
i'm looking forward to see and hear you driving on the Belguim roads with the KR500. I will admire that beautiful 2-stroke monster
Posted: Sat Nov 21, 2009 5:54 pm
FLaT-SiX wrote:Jan.......it's impressive, fantastic project =D>
you'll have to come to the tracks to hear it
exhaust is adapted. had to cut it 7 times to twist it in the right direction (and cutting made it also far more easier to get rid off 2 huge dents).
compared to KR1's exhausts, that is one huge m****rf*cker
Posted: Sat Nov 21, 2009 6:51 pm
by KwakOn
good work, great pics.
=D> =D>
Posted: Sun Nov 22, 2009 5:57 pm
by garye345
Big hat tip to you Jan,Class =D>
Posted: Mon Nov 23, 2009 7:54 am
by TwoStroke Institute
WTF did you weld that pipe with???? It's a crime
Posted: Mon Nov 23, 2009 9:00 am
by KR-1R
right about now,
"a face only a mother could love" springs to mind...
TwoStroke Institute wrote:Here you go Sheik some pipe developement for you
...a bit less time in Surf class and a bit more time in Shop class, LoZza?
Posted: Mon Nov 23, 2009 11:03 am
by garye345
TwoStroke Institute wrote:WTF did you weld that pipe with???? It's a crime
My guess is.....a welder!
Is the saying something like"Don't mistake the container for the content"?
Or is everything to be judged on looks?
Posted: Mon Nov 23, 2009 3:57 pm
by NOS EXUP
That will hold - plenty of penetration
whats the problem
Looking Good.....
Posted: Mon Nov 23, 2009 10:42 pm
well, wish I had a TIG, but if I ever buy one, it will be one that also can weld Alumnium, and they are way to expensive for me at the moment.
and you're right, for the moment it looks like crap but it does the job
finishing it is for when I now everything is working ok and the effort isn't wasted .
put on a radiator today : from a TDM850.
might be a good alternative for a KR1 to, allthough it might be a bit too wide.
pipes are where they should be, and it's twice as thick as a standard one.
measures :
TDM : 39 x 19.5 x 3.5
KR1 : 35 x 23.5 x 1.5
Posted: Wed Feb 03, 2010 8:03 pm
took me about a month, just to get the kick on
kick shaft was inside the frame, and just mm's under the frame. made a support that bolts into the frame, with a teflon "bush-bearring" inside, trapped shaft to get the forces from one side to the other, and with a sleeve over it so they stay where they have to be.
Posted: Sat Feb 13, 2010 12:59 pm
by Vollegaaz
Nice Job Bros
Posted: Mon Feb 22, 2010 10:30 pm
silencers are finished. all homemade.
volume of both is a bit bigger than the original Kwak one, in an attempt to get it as silent as possible. Didn't go for one big one as I didn't have a aluminium tube big enough.
still need to make a bracket to support them.
Posted: Tue Feb 23, 2010 12:38 pm
by KwakOn
=D> =D>
like the look.
surely the Y section would 'silence' quite a bit of the sting as well. Its the first split in a 2T exhuast that I have seen. Hope it works for you.
Posted: Tue Feb 23, 2010 1:32 pm
by scooble
I've seen some Aprilia RS50's use this system - purely for pose value (for the Aprilia that is).
Also found using that ceramic exhaust bandage makes a big difference to the volume too. I have nikons and they're quieter than some standard KR's
