3rd round of the Victoria Motorcycle Club Winter Series
Probably a little bit out of the way for you guys in the UK.
I will be racing in F3 or Superlite as they call it now. Stacked with SV650s and highly modified 400s or 450s as they are allowed to bore them out.
Also Post Classis pre 89 junior (up to 600cc).
Only one other 250cc machine entered in F3. An NSR.
Check out the web site www.vicclub.co.nz
#142 KR1 250B
George
Manfeild NZ 19th of July
- nzkr1
What type of tuning etc are you allowed to do? Can you change forks, calipers fairings etc?
- nzkr1
In F3 as long as it looks like a KR1 or RGV etc anything goes. Must retain standard cc. No big bore kits Carbs and exhaust unrestricted. Can replace front forks, brakes, wheels, rear suspension linkages and shock. Must retain stock swingarm. Fairings, tank and seat optional but must be of standard profile. Sub frame can be replaced. Any internal mods are allowed.
As for Post Classis pre 89. If you replace anything it must be off a bike of the same era.
No big bore kits on a stroker but the 400's can use them?
- nzkr1
Hi Col
Manfeild is in Feilding. If you need directions check out the map section in www.google.co.nz
Cheers George
Cheers George
