Anyway, the thing that stops most fitments is the fact that on the KR the shock lies on a bit of a slope compared with some others and the spring tends to clout the swingarm. So I've come up with this
The basic idea is to push the shock backwards to stand more upright and also as I'm going to be using an r6 shock to compensate for the slightly extra length so I can use std KR dogbones and wheel etc.
Bare in mind it's the prototype and it still needs the end bits machining round (plus a bit machining out of the centre section for clearance on the actual shock.)
But fit is spot on and it bolts up solid using the original shock mounting bolt.
This should then allow zxr250, szr660, tzr1254dl/hw swingers to go in without any clearance problems on the spring. They all have the advantage that the bottom shock mounts are very close to the kr and only need a couple of spacers making.
This is how it looks fitted
Could also help with just mounting an r6 shock, save on new dogbones and having to mess with altering the bush as I could get them made to fit the original Yam bush.
No I've no idea if this is going to work, I'll keep you posted
Code has been done for it so should be able to churn them out if needed.
