Fork Spring Length?
Jiffi77
Fork Spring Length?
Post by Jiffi77 » Sun Mar 25, 2018 5:33 pm
Hi, just in the process of re-building my forks (KR1S) measured the fork springs and they are 438mm long, the manual states they should be 468mm - can anyone confirm if the length in the manual is correct??
Re: Fork Spring Length?
Post by JanBros » Sun Mar 25, 2018 6:37 pm
checked my manual :
KR1 springs are 450, service limit is 442. the inner legs are interchangeable, so that might be a possibility.
Then in the KR1S manual I have, indeed it says 468mm, but someone drew a line through that and wrote 438 next to it. and as service limit he wrote 429mm ??
he also changed the oil capacity : 336 when changing oil, 396 when dry.
It's been over ten years since Ive had original forks in my bike/hand, so can't realy say what is what. I knew they were different lengths (KR1-KR1S), but don't know which are longer.
Jiffi77
Post by Jiffi77 » Sun Mar 25, 2018 9:18 pm
Cheers Janbros, I'll keep that info in mind as I will probably rebuild these with these springs, is the air-gap measurement changed or as per manual? In fairness I don't know the history of these forks, they came off an ex-race bike I bought years ago, I thought I would practice and re-build these before re-building the original ones. It's ended up costing me a small fortune with new bushes, seals and fork seal driver!!
