when i run the bike all the petrol starts pissing out all the fuel but when its warm and gets to really high revs it stops?
Whats the problem and how do i solve it?
Is it just muck in the petrol tank?
Any ideas and suggestions would be grateful, thanks
Matty
Carbs pissin..? help
23, Racing a zx9r in Aintree race club.
Ex Kr1 owner.....one day again.
- mr_bungholeo
it sounds like the dreaded carb hight or shut off valves...set the floats to 20mm as per the manual...and while your float bowl is off blow down the fuel pipe and see what hight they shut off at...check out this thread
viewtopic.php?t=2461
dont forget that the petrol tanks on these old girls r 17 years old and crap and rust has build up inside the tank so fit inline filters and it should stop future problems....
hope it helps...
hope it helps...
danny harris.....R.I.P
gone but totally forgotten...
There's a few of us have had this problem. Best thing to do is to drain and clean your petrol tank, petseal the inside of it, and remove, check and clean the fuel tap and filter and fit new o-rings and seals in the tap if needed. pop a couple of inline filters in and clean out your carbs.
Yep recieved it on Saturday. Will pop it into the bank today and get the rev counter posted to you ASAP.
