just got my quote back from Graham file ref my race engine and i hope santa brings me some GF gift vouchers !!!
will have to do a little shopping around first, i still fancy a 300cc conversion !!
will be sending my bits off after the new year and hopefully have the engine rebuilt for march
Hi Mark,
Work to KR-1S, estimate,
1, Crankcases, are flowed and matched to cylinders, £120-00
I can also tune the inlet stubs/manifolds, £40
2, Cylinders are tuned, exhaust ports, aux ex. ports, transfers, scavenge entries all tuned.
Match power valves. £140 per cyl.
If the cylinder plating is in good condition it shouldn't need replating,
I'll look at them and call you.
3, Machine head to 26J piston squish angle, and volume to spec, £100-00
4, Rebuild crank, parts, 4 bearings £80-00
4 seals £60-00
2,rod kits inc. race b/ends,&
small end bearings £120-00
rebuild crank labour, minimum charge £60-00 -
strip & build 1 crank from 2 maximumcharge £100-00
Mark, as quoted on the phone the other day, these are the prices you requested, if there's anything else you need to know please call or mail, all tuning is for unleaded pump fuel unless you are running avgas etc. as I said, once tuned I'll help you out with any setup spec you require,
Hope this helps, cheers, Graham.
Graham file tuning
- corky
Graham file tuning
kr1s project wanted
aprillia rs125 track bike
03 r6 race/trackbike
dr500 flat tracker project
- SHimmer45
- corky
- Site Admin
- corky
spoke to graham again, as i am still awaiting a lhs kr1s barrel !! asked him a few Q,s ....
1) i havnt decided whether to run on avgas or unleaded what do you think pros/cons?
2) also i will be running 35mm carbs and a pressurised airbox, so any advice on initial jetting would be helpfull.
3) in regards to your tuning, i have heard that you tune more for midrange than topend is this true?
and also what type of gains am i looking at?
(i was debating the s/stephens 300cc conversion but have been warned away for track/race use as there is not much meat left on the cylinders afterwards !!)
his reply....
Hi Mark, thanks for message,
Basically my tuning ethic is make the bike faster, the main performance gain is through torque, more torque= more power, everywhere.
I get good gains through the rev range and this is reflected in the drive of the bike, the days of nothing then BANG and off it goes, are left securely in the past!
I always remember the first dyno graph of an engine I did and it was basically a 45degree line, power all the way, no flatspots.
We'll have to have a proper chat regarding the airbox mods you're doing, just a few things to watch out for.
Avgas gives you a wider margin for jetting correctly to the conditions, because of the lead and the burn speed, unleaded has come a long long way since it was first made, and super unleaded is ok, but I must know because head spec will be slightly different.
If you can get avgas easily I would go for 50/50 with super unleaded.
I've never gone down the big bore route, and never would, too many cons and not enough pros!!! Sounds good on the spec sheet though!!,
definitely going to use his services just need a barrel !!!! [-o< [-o<
his reply....
kr1s project wanted
I'd love to see a dyno comparison between a File motor and one of yours. Even just to see what difference there is in the torque curve.mj43 wrote:In my books Graham is sound and though I now do my own work I keep in touch and bounce ideas off him.
Deffo the man for tuning a KR.
