Just bought a KR-1S, very pleased with it. A few questions - should the oil light stay on whilst warming up? Where do I put the oil if its low? Is the oil filler on the RHS gearbox oil?
Please help
Oil light
- Garry
i assume you are being serious
oil light should stay on in neutral but go out when in gear - if it comes
on when in gear it needs topping up
filler is under the seat - RH tank as you sit on the bike - dont put it
in the other one - thats for coolant
only use good brand fully synthetic 2 stroke oil and you should be ok
good luck
good luck
- mr_bungholeo
The oil filler on the engine clutch cover on the RHS is for the gearbox oil. The RHS one under the seat is for the two stroke oil.
Thanks for you help Garry, I have seen the error of my ways. Have not had the bike in gear as it still sits in the garage since being delivered, with no MOT, so haven't ridden it yet.
I do know where two-stroke oil and coolant go but was not familiar with bikes that have an oil light which stays on after start up.
I am totally serious - don't want to ruin my new bike before I've ridden it
- mr_bungholeo
...as elf said....right of the engine is gearbox oil...under the rider seat on the left is your coolant...on the right is your 2 stroke....the best you can get....check you can see oil in the clear pipes on the right of the engine as you look down the fairing before you start it up for the first time....enjoy...
danny harris.....R.I.P
gone but totally forgotten...
