CAN YOU RESURFACE CALIPER PISTONS
Braking issues
bsa70
Post by bsa70 » Wed Sep 06, 2017 4:21 pm
Hi can you resurface caliper pistons with emery paper, and if so how much can be took off
thanks bsa
Re: CAN YOU RESURFACE CALIPER PISTONS
Post by headcoats » Tue Sep 12, 2017 11:15 am
Heading for quick failure of the seals IMO
You can get stainless pistons for less money than genuine and don't forget the red rubber grease !
Post by 500bernie » Tue Sep 12, 2017 9:21 pm
I used the stainless steel pistons with dot 5 silicone fluid (no rubber grease).
No problems at all, the feel is solid.
And hopefully nothing to corrode.
