Rear caliper disassembly
Braking issues
Jiffi77
Post by Jiffi77 » Thu Jun 29, 2017 10:47 pm
Trying to rebuild my rear brake caliper, I've removed the pistons and would like to remove the sliding pins as they seem to be seized, are these supposed to be removed and if so does anyone know how I do this?
Re: Rear caliper disassembly
Post by SP_BOTT » Fri Jun 30, 2017 8:20 am
The big 'C' bracket should just slide out of the caliper, the only thing holding it in should be the rubber guides, so sounds like yours is corroded in the caliper body, brute force, lots of anti seize should get it sliding, but be careful with the boots as they aren't cheap to replace.
If you just want to remove the pins off the bracket?? some certain types are 'just' threaded in (can't see any reason to do this though)
Jiffi77
Post by Jiffi77 » Sat Jul 01, 2017 10:21 am
Cheers, managed to remove the slider thing from the caliper body, now jusdt need to remove the rubber boot clean-up and reassemble.
Users browsing this forum: No registered users and 0 guests
