Hello!
I had occasion and I decided to bought two Kawas from Greece. Bikes in quite good conditions. The black one need to rebuilt the engine, because compression on each piston is close to 5 bar. The red one have 9 bar so I will use him to start in Polish Classic Championship in Youngtimer 500 group.
Now I will complete all the parts which I need. Already bought new chambers (waiting for a package), new gasket for engine (I will draw all of them to produce them later for own use and share here). Subframe is too havy and not matched with racing tail fairing as you see thats why I wants to build a new one. Electric wiring is already done, I removed all not needed cables and I decided to put ECU and accumulator on the front. Accumulator I replaced with the small one. Looking good. I will try to put all modification with photos here and I will be greatful for your opinion.
