Page 1 of 4
KR1S Project
Posted: Tue Feb 14, 2017 2:21 pm
by Garry
I bought KR1Lee's 2 projects off him last October (see for sale section)
Due to the time of year (cold) - progress has been a bit slow
First thing i did was get the cracked engine mount welded on the KR1S frame
One of the engines was seized but complete - stripped the top end off and it was the crank which was solid (good
news in a way)
The other engine had a seized crank with no top end
I had this spare bottom end sitting in my shed
Gave it a bit of a clean
I mated this with the top end and loosely assembled a mock bike in the KR1 frame to see what it sounded like - and whether i needed to do any major work/spending before taking things further.
Fitted minimal electrics and fuelling just to get it running and no nasty noises. I had overflowing carbs problem
which didn't help but nothing which can't be fixed.
Now i know the basics are okay i can get on with the build. I won't be throwing money at it. Just fixing what
needs doing and cleaning up with the intention of making a reliable
tidy bike.
I intend to keep the reverse black/green paint scheme already on the bodywork
Weather seems to be picking up so should be able to make some good progress soon
Re: KR1S Project
Posted: Tue Feb 14, 2017 11:14 pm
by Binetta Steve
Well done Garry, there nothing in the TV worth watching, and we all love a rebuild thread!
Re: KR1S Project
Posted: Wed Feb 15, 2017 12:15 am
More photos Garry =D> =D> =D>
Re: KR1S Project
Posted: Thu Mar 30, 2017 1:52 pm
by Garry
Thanks Bernie/Steve
Been slowed up with some decorating
However have given the engine a further clean - will look at it again once i have a rolling chassis
Also gave the frame and swing arm a spray
And now back together
Next job is these
As i have said before it's not going to be a money pit or show winner so got to keep a reign on costs as far as possible and re-use if serviceable
Re: KR1S Project
Posted: Thu Mar 30, 2017 3:44 pm
by podman
Good work mate, made lots of progress.
Re: KR1S Project
Posted: Wed Apr 05, 2017 1:29 pm
by Garry
Tried polishing the yokes but after few hours still wasn't happy
So decided to paint and lacquer them, cleaned up the bearings and races and refitted. All feels good.
Next job is to make a good pair out of these. KR1S bottoms mated to KR1 stanchions (these have the best chrome in swept area and will be able to
put the bad chrome at the top facing the frame) Have got some new OE seals.
Re: KR1S Project
Posted: Sat May 27, 2017 6:21 pm
by Garry
Forks were a bigger problem than i thought (thanks for the replies in the technical section).
All had the damper bolts loctited in.
One eventually came loose, SEP managed to free the second one (they also did the frame weld). I am afraid the KR1 lowers had to
get the hacksaw treatment
as their value didn't warrant more expenditure.
Impact gun is probably the best way to go - but i don't have one and don't know anyone who does.
Anyway got them in bits
Contents of KR1S forks are the top items in below photo - non standard and don't come to bits so used the KR1 springs (bottom items).
I know KR1 springs are slightly different length but this won't be a problem.
Anyway all back together and now in place.
Can fit switches and carbs.next
Re: KR1S Project
Posted: Sat May 27, 2017 8:43 pm
by Binetta Steve
Going to start looking more like a bike soon, once the carbs switches etc get fitted.
Re: KR1S Project
Posted: Sun May 28, 2017 8:03 am
Great work Garry
Whats next?
Re: KR1S Project
Posted: Mon May 29, 2017 7:41 am
by SP_BOTT
Any idea what the mod on the forks are, because that spacer is massive in the top of the pic, I'd assume the springs are very strong as they look to have very limited stroke on them?? Has the bottom been modified as well, as from memory, I thought the damper tube can be removed on 's' forks.
Re: KR1S Project
Posted: Mon May 29, 2017 5:36 pm
by Garry
Cleaned up some switch gear and fitted along with throttle, new LH grip (RH had no wear) and carbs
Next job is this Bernie - brakes
Regarding the S fork internals.
The damper rod doesn't appear to come apart from the stanchion readily - it is not the standard one (only has one oil hole) and if you look at it from the top it has a round opening rather than the star shape (if you know what i mean). Not sure how you would tighten it up again.
Re: KR1S Project
Posted: Thu Jun 01, 2017 11:35 am
by Garry
Brakes all cleaned and calipers painted
Just got to reassemble now
Hoses have come up nice - another clean once in place and should be okay
Next job is the front wheel.
Re: KR1S Project
Posted: Sat Jun 03, 2017 5:43 pm
by c&c
Looking good...
Re: KR1S Project
Posted: Sun Jun 04, 2017 11:34 am
by Garry
Thats another job done
Going to see what can be done with this lot this week - will get them looked at to see if a rebuild is viable with a new spring
Re: KR1S Project
Posted: Mon Jun 19, 2017 6:27 am
by Garry
Waiting for the shock to be rebuilt so thought i would do a few other things in the meantime
Gave the front mudguard a clean and spray. It needs a bit more polishing to finish but happy with the result.
I have never had much luck repairing plastics in the past - including plastic welding
Read some good reviews of this item so bought some from Halfords . Got to say i am well impressed. It seems to make a strong join with a minimum amount of product.
I also bought a nice set of discs which have cleaned up well. The centres have a few scratch marks but will leave them as they are since the original finish seems quite tough.
