Engine rebuild
Posted: Sat Nov 12, 2016 7:34 pm
by SP_BOTT
Hi, has a pictorial engine rebuild been done on the site?? can't find anything so far, and can't remember how it came apart last year
for starters, do you just pop the crank in, seal the cases, and bolt it together?? was hoping to do something on it tomorrow. or are there balance bits etc that need doing first???
cheers
Re: Engine rebuild
Posted: Sat Nov 12, 2016 7:50 pm
by Gerrit
One you should never forget is to fit the gearbox input shaft bearing (the one behind the clutch) before boxing up the cases. If you do forget, you'll have to split the cases again.
Re: Engine rebuild
Posted: Sat Nov 12, 2016 8:20 pm
by jarno
Sp_bott
Hope this helps a little
viewtopic.php?f=8&t=11554
Cheers Jarno,
Re: Engine rebuild
Posted: Sat Nov 12, 2016 9:14 pm
by SP_BOTT
Thanks guys, good advice =D> after reading that, now wondering whether to have the crank rebuilt, or just try it, not hard to remove the engine if a seal etc leaks, just my time like most on here.
Re: Engine rebuild
Posted: Sat Nov 12, 2016 11:37 pm
by Gerrit
If you can move the inner crankshaft main bearings on the shaft you definitely wil need a crank rebuild.
Re: Engine rebuild
Posted: Sun Nov 13, 2016 12:25 am
you can download the service manual at the homepage, in there is step by step explained how to dismantle the engine and put it back together.
Re: Engine rebuild
Posted: Sun Nov 13, 2016 9:38 am
by SP_BOTT
Gerrit wrote:If you can move the inner crankshaft main bearings on the shaft you definitely wil need a crank rebuild.
Bearings feel and spin with no clattering so think they are all good, replaced the stator end seal, but other seals just look a little worn on the outside, probably me being a bit picky, as I know they don't move, maybe a slight coating of Yamabond on assembly.
I do have all the manuals in paper form, but good clear colour pics are a bit easier to refer to.
Re: Engine rebuild
Posted: Sun Nov 13, 2016 7:53 pm
by Gerrit
What I meant is "Can you slide the inner main bearings sideways on the centre shaft?" If so the interference fit is gone and the centre shaft will need replacing.
Re: Engine rebuild
Posted: Sun Nov 13, 2016 10:00 pm
by SP_BOTT
Thanks Gerrit, but glad to say, the bearings are solid on the shaft and won't move.
Got most of it together today, but lost the gearbox clusters,
![Embarassed :oops:](./images/smilies/icon_redface.gif)
so I will carry on tomorrow, and see how far I get, need a gasket set, so it's not going to be completed, for quite some time
Also found a good thread by Daz680?? on his rebuild
