So started work on the box of bits I brought to make in to a MITO 350 Decided to fit a NC29 swingarm as I wanted to use a 160 rear tyre. But found it was 3" shorter than a standard arm. It weighed 3.6 kilos lighter though
MITO 350
Re: MITO 350
Very cool Phil =D>
Re: MITO 350
Looks like a great project, what running gear and suspension will you be using?
Re: MITO 350
Will hopefully be using an Ohlins or Wp shock. Need the shortest off I can find so think fireblade or early cbr. Front end i either going to be Ducati o Buell to keep single front disc.
Re: MITO 350
any special plns with the engine ?
Re: MITO 350
To be honest Jan this years plan is to try and get it up and running then maybe do motor next year.JanBros wrote:any special plns with the engine ?
Started to make rear shock mount bracket today.
