Titanium gearbox parts
Piccy to follow title says it all
Things I do to save weight
Might be cheaper to go on a diet
- mr_bungholeo
2 poo's and a wee is worth 5.5mph!! also proven at mira that bulimic road testers once got 57mph out of an mz 125 once! now that is a grand increase of 50% more speed! even if it meant been built like rik waller, if that meant i could have have the ti g/box then watch out mcdonalds here i come!
- mr_bungholeo
I asked for 9 and got 8
I can get some more made - they work out at £3 each once I have rounded up to the nearest £ so say a tenner for a set of 3 including postage in the UK.
Standard items are £2.15 on the Z-power site
The size is slightly different to standard to take out some of the slop. They are due to be tested in two KR's at Mallory so will be able to report next week if they work or not
I am going to get 30 made up so ten sets.
Also getting some clutch spring holders made up. These are the 5 pointed thing that holds your clutch springs down. They are die cast and brittle as hell. I have manged to break a couple in the past and I know they are listed as NLA. They were £32.75
Drew up a replacement part this morning just need to get them costed.
New ones will be aircraft spec alloy bit stronger than standard and won't be brittle.
- mr_bungholeo
